Durango smart access cable
Can anyone tell me where the smart access cable location is on a 2021 dodge durango
If you are sitting in the passenger seat, remove the cover under the glove box, its held by 3 clips in the front.
The security gateway is located on the left up fairly high on the center stack tunnel, best to use a flashlight.
I just did my 2020 and it takes a little bit of a tug to get the existing plug out, but don't pull by the wires.
There are two plugs in it, one larger than the other, just pull the one thats the size of the bypass cable.
Then it just goes inline and should not take more than 10 minutes all told and yes it really works!
I got it. Thanks for the reply
