Hey all, I?m relatively new to tuning. I?ve searched all of google but can?t seem to find any one with a similar issue. Recently I developed an issue with my car that?s causing me to bog down past ~40% throttle at any rpm. I have a wideband set up while data logging. I logged my injector pulsewidth and it seems like every time the throttle goes past 40-50% it shoots the pulsewidth until it chokes the car completely at 26+ ms while my wideband reads in the 8s! I disabled the maf and ran speed density only and it seemed to prevent the issue from happening so severely though it still dropped down to high 10s. That prompted me to determine my maf is causing that issue for some reason so I replaced it, re-enabled the settings I changed to revert to speed density only, but the problem came back. My commanded AFR is somewhere in the low to mid 13s so I?m not sure why it?s going so low. The tune on the car isn?t the best (I bought it like that but it was perfectly driveable. I just started researching on how to fine tune it but I?m running into this issue). Im currently at work and don?t have my laptop but I will upload both a short log as well as my current tune.
Also, I?m having a separate issue with the histograms. It seems like no matter what I try I cannot get them to fill out data when logging. All of the preset histograms that come with it work but mine do not and I can?t figure out why. I?m logging everything I need to and have followed tuning videos on how to set them up properly to no avail. If anyone could help me out I?d greatly appreciate it as these issues are preventing me from tuning my car so I?m only driving it the couple miles I need to drive every day for work. Thanks in advance!
