Results 1 to 4 of 4
Thread: Added Maggy 2300 and car is super lean at idle.
    Aug 2016
    SE WI
    87
    STFT goes to 25+ since Maggy install.. If left idling, I get CEL for both banks lean. Fueling cleans up after rpms/mph comes up.
    Maggy was pro-installed by long time Vet Tech.
    I installed stock tune and got same results.
    I am fairly new to LT4 tuning. Appreciate any suggestions.Attachment 108687
    Aug 2009
    Calibrating
    3,378
    I bet it’s a vac leak somewhere, changing from a stock size MAF tube and just a blower change won’t need a 30% increase in fuel at idle.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2020
    Mn
    33
    Agreed with vacuum leak. I'm a long time GM tech and I installed one of these a couple months ago. Torqued manifold bolts to spec twice and used blue loctite. Checked every vacuum line as idle was lean. Tightened the bolts again-just snugged tight no torque wrench and rechecked. Good to go. Was sucking a small amount of air through the intake gaskets. The lean idle showed up after a couple test drives. Always check the basics before you go down a rabbit hole.
    Aug 2016
    SE WI
    87
    Found leak. Snout on 2300 has a hole on top to support a clamp for wiring or plumbing. My 2300 had the hole drilled through into air stream. Tech found it by forcing smoke through intake system. A little sealant and a bolt fixed my problem..
