Results 1 to 6 of 6
Thread: 09 G8 GT cooling fans high speed all the time
    May 2020
    3
    I performed a dod delete, I shut off the dod. When I start the car cold or hot the fans come on and don?t shut off. I look at the scanner koef - relays off, fan desire 0%, as soon as I start the engine the fan relays turn on and and the fan desire goes to 99.6%. I have been adjusting the fan settings with no luck, any help will be appreciated.
    Dec 2019
    MS
    567
    What does the ECT read when your data logging?
    I had a 2009 3500HD do something similar when the wires for the ECT sensor had rubbed the insulation off on the edge of the cylinder head.
    May 2020
    3
    Once the engine is warmed up 195 roughly. Ect is working correctly
    7,615
    Well you either missed something during reassembly or have a tune file problem, with no more information than you've given and no tune+log posted it's kind of impossible to say.
    Maybe it's haunted? I guess you could have a priest look at it, sprinkle some Holy Water?
    7,615
    The coolant temp PID will lie to you under certain fault conditions. It's stupid and frustrating when it happens and I have never found an explanation for why they designed it to do that, but it does.
    May 2020
    3
    Here is the log file from today
