New member, need some direction please.
Brand new to HP tuners. Got this to help with my 2008 F150 5.4 3v (a constant project so why not) I've disabled the VCTs for shunted phasers.
I've noticed there is no selection for target RPM, and I'd like to increase idle RPM to help keep hot idle oil pressure just a bit higher. I don't need much to build the pressure... (Yes I know, likely other issues here, I'm hoping to limp this engine along it was recently rebuilt from the crank up with new 360HV oil pump OEM everything, etc. the ever so light 'knock' only shows when the oil pressure dips to 25PSI at hot idle.) Time to save for a new motor - no more rebuilds.
That's really all I'd like to do at the moment... not sure about how to unlock hidden power or anything like that. Didn't see any tunes in the tune search...?
Thanks.
The 2008 F150 I looked at has idle RPM settings. Post your tune so we can help you.
