Thread: Ba xr8 scanner missing a lot of pids
    Apr 2015
    13
    Hey guys, currently plugged into a ba xr8 , read and write works fine but the scanner has next to no pids , no throttle percentage , no knock retard and about 20 others missing .
    Only have stft bank 1 and timing .
    Running latest stable software from hp.
    Oct 2020
    I have had this problem before on a BA XR6T PCM in a standalone config. When I changed the VSS to "ignore VID" I lost most scanner functions.
    Since then I have resolved a similar problem by selecting [comms>re poll for supported paramaters]
    Aug 2021
    4
    im having this exact same issue
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    283
    Always repol first however some early BA's do not automatically identify in the HP system. Support can add these, you need to know what is missing (ideally PID ID numbers) also send the Infolog, Debug, an example log ensuring you are on a current version. I have had to do this on two occasions with early BA.
