Results 1 to 10 of 10
Thread: noob here pls help...mustang v6 2013
    Feb 2020
    12
    i have encountered some dtc's... the ltft stay stuck at 29.7 and evap shows -232...knocks are popping up.. just a cold intake in the car
    posted log...pls advice
    Dec 2017
    767
    What cold air intake, if it’s a tune required you will need to tune the maf.
    Feb 2020
    12
    so ltft is stuck due to maf??? did you see the codes?
    Feb 2020
    12
    k&n cold air...
    13,576
    There must be a leak after the MAF if all you did was install a cold air intake.
    Feb 2020
    12
    yeah...and no cats in it...... only this two things
    stock injectors? does it have e85 in it or something?
    Feb 2020
    12
    full stock
    can you hear any air sucking noises under the hood? I know it's hard to hear but it seems like a vacuum leak could be something to look for. I can't imagine your fuel to be that far off with just a cai, those things are usually so close you can just slap one on.
    Feb 2020
    12
    will check it up and update ...i have tuned 07 stang also v6 but dint see the way this looks
