Results 1 to 2 of 2
Thread: Wb afr error graph not populating
    Jan 2018
    4
    Hello everybody. New to the forum. Having a problem getting data on my histogram Information in graphs and channels is good, just no info collecting on my histogram. Just purchased the AEM 30-334 Wideband. Please tell me what I am doing wrong. Please see attachment. Thank you.
    May 2003
    South FL
    1,367
    Are you logging commanded EQ Ratio?
    You need the WB sensor logged, then commanded EQ logged. Then when you make the graph you select the prebuilt math for AFR/Lambda Error.
    [email protected]
    Owner/GM Calibrator
