Results 1 to 7 of 7
Thread: 2012 5.3 80lb injectors 80mm t4 turbo fuel milage 6.1 mpg
    Nov 2020
    18
    can anyone tell me whats wrong with this tune truck gets 6.1 mpg and when comes into boost black smokes the goes lean up top
    Advanced Tuner Boosted C6's Avatar
    Dec 2013
    Pennsylvania
    222
    you should be logging a wide band. Also your maf curve should be smoother and you need to pull some timing out because of all the kr you have at wot
    Dec 2013
    Pennsylvania
    222
    Also that injector data seems kind of odd
    Nov 2020
    18
    A shop tuned it for me and it don’t run great it has deka 80lbs in it and it’s only on 8lbs
    Nov 2020
    18
    And I have a wideband it’s just not connected to HP
    13,564
    Yeah that injector data is wrong. It says you are running 127lb/hr injectors right now.
    Even if those 80lb/hr dekas were rated at 43.5 psi and you are running 58psi, that only puts them at low 90lb/hr injectors. Get that stuff fixed or call that shop and tell them they are stupid and need to fix that.
    The MAF airflow freq curve and the VE tables look pretty bad. The MAF curve is terrible, it's not smooth at all.
    Doesn't look like you are running o2 sensors either because they aren't doing anything in that log.
    The timing tables are pretty bad too. They took away all your cruising timing so there goes some of your fuel mileage. A stock timing table will run way up into the upper 30's and low 40's just bumming along on the freeway.
    Your fuel pressure is also dropping under boost but you have that issues with the injectors still. Fix the injector data, redo the entire MAF and VE stuff, the timing and then see if you are dropping fuel pressure. The stock fuel pump is only going to be good for 450-500hp.
    Nov 2020
    18
    Ima just try and do it myself now that I bought HP tuners was just trying to get pointed in the right direction and the shop told me I had bad injectors so I sent them to have them flowed and they were all spot on so needless to say the shops a joke
