Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 2019-up Ranger 2.3 tuning results?
    May 2019
    New Jersey
    14
    Quote Originally Posted by engineermike View Post
    I don’t know what the vid config is, but all of them use the same value. If it were me, I would increase the entire row the same amount.
    Thank you sir!
    Jun 2020
    313
    Does the ranger have a sport shift button? If so, you could apply shift character 2 to sport shifts.
    May 2019
    New Jersey
    14
    It has a Sport Mode - by clicking down from Drive to Sport.
    From looking at the maps, it defintely has pedal characteristics for acc pedal (think pedal commander), and quickly looking at the shifiting schedule it has an upshift, downshift, and coastdown for all the different modes (i have a lariat tremor so it has the terrain modes too it seems in here)
    Jun 2020
    313
    I think the ranger only uses shift character 0 and 2, and 2 is only used in 4L. Might be worth trying out 2 in sport mode.
    Quote Originally Posted by metroplex View Post
    But isn't the torque model based on the VE Modeling for the engine/turbos as-is? If you're trying to push it to an air load higher than it supports, then it doesn't seem to make sense unless you are somehow changing something in the VE (like bigger displacement, bigger turbos, etc...)
    I experimented with the torque/inverse torque tables with the 3.5 in the SHO and I was able to raise the boost quite a bit but otherwise didn't seem to do anything. I had the opportunity to look at a vendor's tune and noticed they tweaked the torque/inverse torque tables as well but for the MP's associated with WOT operation for that particular engine - the changes to those tables basically raised the load values in the inverse torque table.
    VE would be handled by the speed density quadratic equations, the torque model just correlates a torque number to load and vice versa.
    Maybe the V6 software does it differently? It wouldn't be the first time. lol
    All I know is that I hit a hard wall at 2.4 air load and after extending out the TTL and LTT tables, I was able to consistency get a load of 2.6
  6. #26
    May 2019
    New Jersey
    14
    Ah i see - just went into the characteristics table... what exactly does this do? you are right - they are all 0 except for 4x4L is 2.
  7. #27
    Jun 2020
    313
    Quote Originally Posted by Rbelar21 View Post
    Typically the higher shift characters are more aggressive, faster shifts.
  8. #28
    May 2019
    New Jersey
    14
    Welp - just playing with power enrichment, torque truncation on trans, upping the Max Torque limits to accept the stock table numbers WOT, and working with the LSPI limits - she moves for sure.
    boost seemed to be limited to around 10-16psi stock, now have it around 16-19 in a linear fashion. Feels phenomenal and I didnt even up Driver Demand, add spark, etc yet.
  9. #29
    Sep 2018
    38
    It just depends. I know on my 2018 f150 I had to mess with it slightly in a couple places because I wanted more part throttle load. It would throw a wrench quick as hell just cruising down the interstate and hit a certain hill. I also used it to smooth out spikes in the boost on shift. It was pretty easy to compare what the raptors had going on and see what limits and loads I was hitting.
    Now I was being a little on the aggressive side but hey its mine.
