Originally Posted by
engineermike
What are you calling "max torque values"? The driver demand?
Tread lightly because the spark tables aren't defined past 2.0 load so it won't ramp timing down as load exceeds 2.0.
I reviewed your log and your knock retard curve looks like it's working as it should. It's making a saw tooth pattern where it advances until it sees knock, retards, and so on. It does this nearly the entire log. I'd like to see how actual timing compares to MBT. If you're trying to optimize timing, then I would definitely log MBT, Borderline, and Timing on one graph. It's a little surprising that you can't reach MBT at those light loads at cruise.
