Originally Posted by
engineermike
I see it. I don't know what's causing it off-hand, but if I would put the fuel source and lambda on the highest data rate possible and delete most of those PIDs off your list to speed up logging of the relevant data. Airlimit source and max sources can all come off, as well as baro, inferred octane, charge air temp, and others. When diagnosing a problem that happens so fast, you need dense data. I would add "commanded" lambda to the list, though, also on a high data rate.
Another note is that you're hitting the cylinder pressure spark limit. That's an easy one to get around if you so choose.
