Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 121 to 140 of 169
Thread: 2019-up Ranger 2.3 tuning results?
  1. #121
    Tuner jaz|TUNING's Avatar
    May 2022
    Greenwood, AR
    57
    Anyone have an OEM map they can post? I've got a Ranger on order (for awhile now) and would like to get familiar with it before I have it.
  2. #122
    May 2019
    New Jersey
    101
    https://forum.hptuners.com/showthrea...anger-Ecoboost
    PsychoSteve posted one further down the line. Let me know if you need any help - coming from Subaru's its been a very fun time learning about ford's ecosystem. These little things have some balls.
  3. #123
    May 2022
    Greenwood, AR
    57
    Thank you. I come from most of my customers having Subaru. I've tuned quite a bit of Fords, but older... Mostly old Taurus SHO's. Two of them were on TV shows, of that rings any bells.
  4. #124
    May 2019
    New Jersey
    101
    Been almost a full year since I took on my Ranger. Thank you all for all of the information you guys have given me.
    Hitting the drag strip one more time this month before the end of the season. Only other thing would be for me to get it on a dyno, but otherwise it's driving in everyway I could want it to!
  5. #125
    Jan 2015
    565
    Great news, Let us know how it goes!
  6. #126
    Jan 2015
    565
    Ever get back to the drag strip?
  7. #127
    May 2019
    New Jersey
    101
    Unfortunately I couldn't we ended up having to go to a wake...
  8. #128
    Jan 2015
    565
    Oh Im sorry to hear that. Well let us know when you do
  9. #129
    May 2019
    New Jersey
    101
    No worries thanks a ton!
  10. #130
    May 2019
    New Jersey
    101
    So quick question for those that are still around. When it comes to moving towards E30...
    I know that I can update the base Stoich number, or even let the trims handle for it... but when it comes to more power - I start to wonder about boost levels vs Timing..
    For instance, since I have learned the Requested Torque method everything has been fine within the power I want to make. However, if i start requesting more and more torque (sans limits) its obvioulsy going to request more and more load (therein boost), not necessarily more timing, unless i give it to it dynamically or via the tables.
    So in this case - whats the best method? Boost or Spark? Personally I am not sure I want to go over 23psi, theoretically there could be a point where I am requesting enough that it hits 25 psi. Any Advice?
  11. #131
    Jan 2015
    565
    Just my theory and it may be out dated. There is more power to be had with increased boost vs timing and its safer. There is a point of diminishing returns always of course. So i try to go up in boost first. Find the limits of what I'm comfortable with or the turbo efficiency limit or intercooler etc. Then if Im still not seeing any knock, Ill increase timing slowly and track the power gains through a dyno or time slips or dyno software.
    Like I say, I may be out dated
  12. #132
    Jun 2020
    786
    I believe reubone is correct that at the same power level it?s safer to run more boost and less timing vs the opposite. The conflicting part is that more boost and less timing becomes increasingly less efficient. Turbos run out of flow capacity and efficiency falls, backpressure builds up, intercooler sheat soak, and you could run out of fuel system. More timing is more efficient and can do more power with less air and cooling, but also it?s more dangerous.
    The age old question?
  13. #133
    Jun 2019
    Wisconsin
    295
    Ford's control strategy will usually prefer timing over boost, if it can hit the same torque at less boost, it will... But if you're already requesting enough torque to try getting more boost, that kinda gets tossed out the window.
    In the past I've preferred boost over timing, but direct injection engines can tolerate more timing before detonation occurs too, so that's something to keep in mind.
    When running e30, you probably don't have to do too much to timing from stock, other than maybe increase cylinder pressure limit timing, then just let the system add in timing until it sees knock and backs off.
  14. #134
    May 2019
    New Jersey
    101
    Thanks all. I?m out in PA for thanksgiving and have good access to corn out here. Seem to have made a nice e30 tune and it feels strong. Upped the cyl pressure timing a bit and limited boost max to about 23.15. Seems to run very strong and is adding timing up to the cyl pressure ceiling nicely with no neg corrections. I?m getting about 8 degrees at WOT and can probably map this a bit more, but it for sure is loving the timing towards higher RPM. It?s very cool to see all of these things work together once you get past the limiters.
  15. #135
    May 2019
    New Jersey
    101
    How would you all feel about seeing the knock sensors acting like this?
    Am I to close to the threshold - and should I pull back a few degrees (i have breathing room from the boarderline adding tables)....
    It seems as though positive correction is fine, but I feel like the fact that the cyls are not in sync is showing that some cyls are knocking, even though its not negative. When i run e30/e40 i have all cyls in sync and its running as happily as possible.
    12_8_cruise.hpl
  16. #136
    Jun 2020
    786
    I recall one of your earlier logs doing that as well, maybe even when it was stock. I was very surprised to see Ford running this thing into knock on every cylinder at steady-state cruise. If I am right so far, I guess they're very confident in sensing knock at levels low enough such that they don't cause damage. One thing's for sure, it's one way to improve fuel economy, but man...it's running at 1.3 load and about 8 deg timing at steady cruise. It sure seems like it would be able to sustain 80 mph at less than 1.0 load.
  17. #137
    Jun 2019
    Wisconsin
    295
    Not quite 1.5 air load, but it's close... Not in power enrich, no knock, more than 8* timing while actively adding timing.
    I mean, isn't that one of the key benefits of DI, run more advance and keep out of knock?
  18. #138
    May 2019
    New Jersey
    101
    There was a chance i was hitting a hill in these areas, I live in northern NJ so we have quite a few steep hills, even on route 80 where this was logged from.
    Mike, you are correct I see this even with stock map. I really am not comfortable with it, or id rather them all be in sync. One thing I did notice is that it happens in the final gear, so i guess there just might be to much load and it is holding 10th when it shouldnt be.
  19. #139
    Jun 2020
    786
    Not being in sync is perfectly fine and even a good thing. The per cyl is working exactly as it should.
    If it were mine I would cap the knock advance to prevent it. But I have a coyote that runs .35 load and 40 deg timing at cruise.
  20. #140
    May 2019
    New Jersey
    101
    Ok, i think thats the route i am going to take for now anyway, is drop the dynamic advanced down a bit and get it closer. I guess i just have to get used to the per cyl.
