dose anyone happen to have a read with hpt for this year make and model 2012 ram 3500 with the 6.7 cummins
Yes I do
You can just get a generated stock file with HP Tuners though that will be for your specific truck in question
i don't have the truck on hand. just getting in to HP tuner. i know winols software. if you could please share that be great just want to check what maps are there.
thank you
I?ll post up my stock read for you when I get a chance.
sounds good
thank you everytime5.9 have you tuned this ecu? and how did you make out with it
They tune just fine other than HP Tuners killing the 6.7 ECMs. I personally would never use it on a 6.7 again after it bricking my ECM and knowing of multiple other cases of it bricking ECMs on other 6.7 trucks.
so your saying i should stay away from flashing the cm2200 with hp tuner? did you end up getting yours recovered yet?
Me personally, I would. I would stick with MM3, EFILive or EZ Lynk for the 6.7 trucks.
I haven?t had a chance yet to try recovering my original ECM yet.
okay i don't have any of them. i got hp tuner pcmflash bitbox flex.
HP Tuners has caused issues with my TIPM as well. At least those issues don?t affect my truck from being able to run.
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
The TIPM I need to use a WiTech. My Cummins hardware is to connect to the ecm only, directly through the backbone, J1939.
