Hello all. Someone put this 6.0 into an 88 jeep and now it's at my shop. I've always been interested in tuning but now (I inadvertently erased the tune file with factory software) I've just got HP tuners up and running, got the cooling fans and vats problem handled now hitting a snag. This has engine and wiring/pcm from a 2002 escalade but with a 4l80e. I'm getting some shifting codes and believe I needed to change the trans to 4l80e so I did that in the general trans type menu with no change. I saw I may need to switch back to stock tune then change the operating system first? Not sure which one to pick for my application. Thanks for reading, any input is appreciated
All I can find is the .hpt file for now trying to locate the other files will update shortly.
The trans codes are p0740 TCC enable solenoid circuit + p0785 3-2 shift control circuit and it does not shift.
Looks like history log perhaps been built into the .hpt file now?
6.0 commanche.hpt6.0 commanche.hpt
