Results 1 to 12 of 12
Thread: MDS Solenoid Vale (Tuning it to stay open)
    Sep 2020
    41
    Hi all,
    is there an easy way to keep the MDS solenoids open through HPTuners without affecting anything else? Assuming not, but thought I'd re-throw the question out there.
    Thanks,
    ok correct me if I am wrong but commanding the mds solenoid to stay open would mean you are running in 4cyl mode constantly, correct?
    and if I am correct in that, Why would you want to run a v8 as a 4cyl???
    Sep 2020
    41
    I’ve replaced the lifters with non-mds lifters and a supporting cam. I’d like to feed pressurized oil into the gullies permanently to improve the lifters lubrication and thereby reducing the chance of a lifter roller failure. If I can’t, I’ll just pull the 4 solenoids and use plugs. Should have the same effect.
    Oct 2005
    baton rouge la
    411
    Quote Originally Posted by sPHYNX View Post
    just disable mds
    Sep 2020
    41
    Not sure I’m explaining it properly, but I want the solenoids open, all the time. Disabled MDS would mean the solenoids are never energized.
    Sep 2017
    Mid West US
    76
    Put the plugs and be done. You cant tune the solenoids to stay open as that would affect other parameters for those cylinders as ECM would think it should be cutting fuel etc... Don't forget the the little
    magnets down in the block under the solenoids.
    Sep 2020
    41
    Thanks for the feedback. I’ll order those and move on, was hoping these was an easy way out.
    Jan 2021
    Cape Town
    84
    Quote Originally Posted by UHemiNow View Post
    I agree, remove solenoids and fit plugs in your case. I am not aware of any magnets under the solenoids, news to me.
    2010 Jeep GC 5.7 Eagle Head motor, 2" OME lift, cats removed, full MDS delete
    Aug 2017
    Quakertown PA
    478
    Just dump the MDS Solenoids even with them Disabled they still restrict some of the flow , the plunger from the MDS sits about 1/4 of the way in that galley.
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    478
    there are no magnets under the solenoids, the plunger has a magnet in it..
    https://youtu.be/Gl5a5kY1D0c
    G3 Hemi Videos
    Jan 2021
    Cape Town
    84
    Thanks PurpleRam for clearing that up.
    sPHYNX, please give feedback on fuel consumption once you have got rid of the MDS system.
    Oct 2005
    baton rouge la
    411
    Quote Originally Posted by skala308 View Post
    We've rarely seen any decrease in mileage, and generally see an increase. A lot of that can vary depending on driving/road conditions ie a lot of flat highway driving vs stop and go, or hills
