Results 1 to 4 of 4
Thread: Throttle Lag In SD Mode
    Advanced Tuner Boosted C6's Avatar
    Dec 2013
    Pennsylvania
    222
    I have a 2007 ls2 corvette that if I run it in SD mode and blip the throttle to shift down there a delay or lag for the rpms to come up. The log below is full of throttle blips and its alittle rich due to just flashing this tune to get this log.
    Corvette LS2 SD Tune.hpt throttle blip.hpl
    Nov 2006
    2,727
    It's likely a lean spot in the vve or ve table.
    Tuner at PCMofnc.com
    Dec 2013
    Pennsylvania
    222
    hmm ok. Ill have to try and find that spot but I was told when logging for the ve table to be smooth and not to blip the throttle
    MAF in my opinion works way better for those transient situations. I run mine in SD but switch to MAF for inspection reasons here in NY, but boy down bottom seems to be so much more responsive with the MAF. (Installed card MAF in OTR intake and tuned it).
    But as Alvin said, its likely a lean spot just off idle.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
