Results 1 to 7 of 7
Thread: Wideband in Histograms
    Oct 2020
    4
    Hello, I recently purchased HPtuners and I have had it for a couple of weeks now. I got everything set up and I am tuning a 2000 GMC Sierra with an L33 motor in it.
    I got my wideband installed and working through the pro tools and I can see it in the PIDs. My issue is that I am having a hard time getting my wideband to work in the histograms.
    I try to get data on the MAF sensor in hertz along with wideband data. No data is being put into the histogram while I'm logging.
    I've added the wideband in the user-defined parameters and have set it up to go into the histogram but it is showing as a voltage through the parameters.
    I can add a log or anything else I need to help clarify.
    I have added the graph and my sensors.
    Thank you in advance for the responses!
    Australia
    1,977
    do u click the little gear symbol then selecting the pids for the graphs ? that will only show polled pids encase u are choosing one that isnt used
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post a Tune and a Log
    Oct 2020
    4
    Log File
    Sorry for the late reply, the last couple of weeks have been extremely busy. Here is a log file.
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Quote Originally Posted by SierraTime View Post
    Did you add EQ Ratio Error as your input sensor in the MAF Histogram?
    Oct 2020
    4
    Quote Originally Posted by outlaw_50 View Post
    Yes, I added the EQ Ratio Error. I have the input set as the blue wire input from the pro link. It comes through as voltage which what I am guessing my issue is, I just can't figure out what I need to change.
    Oct 2020
    4
    Just checking if anyone had any suggestions. I haven't had time to look around more in the scanner but any help would be much appreciated.
