Hello HPTuners,
I was wondering if anyone can assist with tuning the 2007 FJ Cruiser 1GR-FE single VVTI. I am hoping to get more power from the tuning with HPtuner. I currently have the URD MAF calibrator did a little tune, which I got a dyno @ 216HP with Gear 4.56 tyres 317/75/16 this is without the DT long tube headers. The stock HP pull was 199 to the wheel prior to the tune. I will be removing the URD MAF calibrator as you can not use two different type of tuning as you would not need it with the HPTuner, HPTuner already has all the feature that is needed to tune the MAF and more.
Today I will be tuning the the gear/tyres to update the ECU to match my gear ratio & tyres. I want to be able to go outside the box get more out of the FJ Cruiser before SC. I will add bolt back the DT long tube next week as I needed to take it out for SMOG.
Any help with be appreciated.
R35T
