Results 1 to 2 of 2
Thread: Chanel and graphs for 6l80e
    What channels should I be logging when tuning the transmission? I used Blue cat and it feels great but I want to see if there is TCC or trans slippage.
    Thanks a billion.
    Jul 2020
    VIC Australia
    1,147
    All PCS channels, 20Hz
    Torque converter slip, 20Hz
    TCC pressure
    Torque, 20Hz
    Torque management advance, 20Hz
    Trans slip rpm, 50Hz
    Trans current gear
    PRNDL Status
    Trans shift mode
    Time of latest shit (lol, shift) 1 through 6
    Trans fluid temp
    Trans Input shaft rpm, 20Hz
    Trans output shaft rpm, 20Hz
    TPS
    RPM
    Speed
    To change the polling interval right click the channel and you will see the fly out polling menu. Don't set everything fast as you'll flood the bus. Just the important stuff.
    That will get you started.
    And a chart layout for you to use...
    Transmission_Default.Charts.xml
    Last edited by hjtrbo; 05-08-2021 at 08:49 PM. Reason: Updated channels & added chart layout
