Trying to disable DOD on a 2018 colorado 3.6l. The enable/disable doesnt seem to be doing it like it does on the v8 gm engines. The dic is still showing v4 and v6. And scan tool data is showing the engine switching. Any ideas?
Is there a disable by gear option?
You didn't post the tune to look at.
Raise/lower a bunch of the other settings for the DoD system and see what it does.
Raise the min temp to 300 degrees, lower the engine rpm to 500rpm.
What the heck happened to those timing tables too, never seen anyone try to run 50 degrees of timing at cruising speeds all the time.
Thats not me. Thats the stock file. All I want to do is disable the afm/dod
Keep messing with the settings then, I remember someone having this question a long time ago and some sort of combination of settings worked.
