Results 1 to 2 of 2
Thread: Tuner Changed Gearing In Speedo Menu
    Potential Tuner InstiG8's Avatar
    Apr 2021
    Massachusetts
    Just got my car back from the transmission being rebuilt and I noticed the car shifting soft and slow. They re-flashed the TCM, so I was going to re-write the tune that I had saved so that it would be shifting right again and I just happened to notice that the Final Drive settings were changed. My car has 2.92 gearing, which is what it says under "Ratio", but under "Trans" it says 3.27. Should I change this back to 2.92? I'm assuming they just grabbed a base tune from someone else's car and forgot to change the ratio.
    Oct 2021
    melbourne
    3
    hey mate im a noob to hp tuners but i have had a similar issue you can use gear and tyre wizard to rescale the trans shift points and set final drive ratio
