Results 1 to 3 of 3
Thread: Axis Copying When Values are Different Question
    I'm running an Ls3 with a 4L60E using an E67 and T42. The Ls3 is from an '11 Corvette and originally used an E38, but using a 4L60E required the E67. There are a few areas where I am swapping over data from the E38 to the E67 and am running across different axis values.
    One example is table 12701 Minimum Final Spark on the X axis. My E67 doesn't have the RPM value underlined. The E38 does.
    My question is do I just plug the values I do have in where they match both tables and interpolate between vertical fields or is there a better way in say, excel that I'm not aware of? I've been stuck at this for some time and can't seem to come up with a reasonable answer despite searching/reading. Any guidance would be greatly appreciated.
    ORIGINAL TUNE.hpt
    2011 Grand Sport.hpt
    Jul 2020
    VIC Australia
    1,515
    This will get you 90% of the way there. If there are bugs please let me know and I'll fix them.
    What you will have to do once it is downloaded is remove the .hpl extension so that it becomes a spreadsheet. The forum doesn't allow .xlsm files.
    hjtrbo_3D Lookup.xlsm.hpl
    Thank you!!
    I'll try it tonight.
