From your fuel trims and FDCO areas it looks like a scanner issue. When you switch the command units to Phi instead of lambda it looks correct. The difference matches fuel trims and on DFCO it goes to .85 not 1.177. Make sure you have the latest VCM and update if needed. If that doesnt fix it reach out to support and see if they can correct the units calculation.
For now if you right click the channel and select units Phi, it should correct the numbers. Then use Phi in all your maths, charts, and graphs.
