I have a 2013 E38 ecu with OS 12653674. its from a 2013 silverado with 5.3.
i am running a 2011 l96 6.0 with 2006 4l80e with a t42 tcu OS 24235341
when i first did the swap i had a t56. so i changed the transmission from "automatic" to "manual". of course i then got the 158 mph in scanner. I then decided to go back to an automatic and put the 80e in. did the segment swap and used an 08 express file from repository with a 4.8, 4l80e and e38 ecu. transmission shifts and works great, but i still have the 158 mph in scanner.
the other day i write entire to the original truck tune the ecu came with in hopes to get the mph to possibly be correct, and yet didnt work.
do i need a different OS to make this work? is there something i am missing? can i have the dealer flash a different os onto it?
I am having part throttle drivability issues, and i am thinking its because the ecu is looking for a speed and its stuck at 158.
attached is the working tune in progress. 4_29_2021, 7k shifts 26's conv lock, 7300 limiter_ny2.hpt
any help is appreciated.
thanks
aaron
