Car pulling timing at WOT
Last night I took my car to the track and started to work on dialing timing in and noticed at WOT ranges my timing was 8-10 degrees lower then what it should be. Upon doing a bit of research I realized I needed to log my IAT, ECT, and Torque management timing parameters. I found out my IATs were the main culprit for the loss of timing at the track and I was getting a lot of heat soak in my IAT sensor. I went out this morning and had the pids logging the timing and had far better IATs but now its using the low octane table and not the high octane table even though its not recording any knock. Any other reasons it would reference that table? Attached is my tune.
Thanks!
8L127742 G8 GT timing 1.hpt
what's the setup ? Please post a log
Try increasing your MBT Table by adding 5 degrees to the WOT area and start logging plz
