So I have a LSA ZL1 Camaro. Car has the normal bolt ons, pulley, intake headers. I was installed the DSX aux pump and flex fuel sensor and topped it off with a bunch E until I hit 85%. The idle fluctuates now and seems to bounce and the fuel trims seem to be off. The car was dialed in aces on 93 and I wouldn't want to affect that by screwing with the maf. Is there any changes I can adjust to the alcohol tuning only other then the PE charts?
Also, the fuel pressure dips off up top with the DSX pump. Any tips on that? I was under the impression that we raise the min dc on the fpcm and we should be fine. I raised it significantly and it still sits under 350
