Originally Posted by
PatFarrell
I've got video from my new GoPro 9 with GPS data.
When I use the "_Timer - DateTime - Updated" to display the current time (current to when the video was captured)
it displays it as "April 27, 2021 10:15:22" which is accurate according to UTC/GMT time. I'm really in the US Eastern time, so this should be adjusted with -4 or to EDT (Eastern Daylight Time).
So two questions:
1) How/where do I specify the local timezone?
2) how can I change the format? (I'd like to not print the date but keep the time. Even better would be to just use a HH:MM format
and eliminate the seconds display as well
These can all be changed in the Enhanced Object Script Editor.
Clicking the "Open Script Editor" button on the Timer's Object Properties should bring up this window:
Click on the Background Script button to bring up this view:
From here, you can just edit the variables to format the output how you would like. You probably want:
Code:
// Preferences
TimeZone = -5; // Set the desired UTC timezone here (-8 for Pacific, -7 Mountain, -6 Central, -5 Eastern)
IsDST = true; // Set this to "true" if the date was during Daylight Saving Time (ie summer months)
ShowDate = false;
ShowDateISO = false; // Set to true to show "2018-03-15" instead of "Mar 15, 2018"
ShowTime = true;
ShowTimeAmPm = false; // Set to false to use a 24 hour clock
but you can adjust the TimeZone/IsDST variables to get the correct time. After making adjustments, you can click on the "Update Preview Image" button to refresh the preview with your changes. This is a handy way to make sure that your changes do what you want. If not, then you can just click "Cancel" to back out of the window and lose those changes so that you can start over.
If those variables don't do it for you, you can adjust the code in the Foreground Script view to output it however you'd like.
