So I've noticed something weird going on while working on some tweaks to the SD Portion of my tune. I've noticed it in the past but only seemed to happen once or twice. But I would scrap that log and start over sticking with what was being more consistent. But I can never seem to track down whats causing this. Both logs were taken back to back with ZERO changes to the VE Table in between and at around the same temp and same amount of miles driven.
To sum up what you may be looking at. One log was on the rich side all cells in the green, parked truck shut it off. 5min later started it back up and immediately started seeing lean in all cells almost all being red throughout the log.
