Hi Guys,
I have just swapped a 63k mile 5.3L LMG and 6l80E out of a 2010 Silverado into my 2009 Colorado. It is using the E67 ECM and a Current Performance wiring harness. The truck runs and drives just fine until I stomp down. As soon as it up shifts from 1-2 or 2-3 at WOT it will shut down and the transmission will temporarily lock up causing me or my passengers to always wear brown pants. It will also shut down if it hits the rev limit while doing a burn out at the track.
The traction control options are all disabled, all gear and diff ratios are as they should be. Really not sure what the cause would be as it doesn't throw and codes and there is no CEL.
I have tried 2 "professional" tuners and neither of which were of any help.
I have attached the tune file. Engine wise it is stock as stock can be internally, the DOD is disabled in the software. A Volant intake, Hooker swap manifolds and a custom 2.5" to 3" exhaust are the only mods.
Any insight would be greatly appreciated
