Hey all, looking for a bit of advice here on a E67 project. It's a TBSS that has a 383ci engine and Procharger. Will be a SD tune with ZR1 MAP. Happens to have ID1700 injectors in it which are overkill, however what I'm trying to work with. The IFR of the E67 is limited to 63lb/hr which makes scaling around 25% to cover the ~190lb/hr flow rate of these injectors at 400kpa.
That said, I'm getting balled up a bit trying to get this all to work right. I'm not able to do the IFR + Volts multiplier trick, nor the IFR + Stoich trick due to the limits of both tables in the mix. I tried to scale the more traditional way that the DSTECK write-up suggests but I'm missing something or have any number of things goofed up. Hoping someone can give me some advice on a 25% multiplier startup tune.
The engine will sometimes crank and fire, however it doesn't want to stay running. Spark is all over the place. AFR's swing wildly between rich and lean.
Attached I have the OEM tune along with one I've been trying to modify to get to idle at least. Likely all modifications are incorrect/junk/trash
If anyone can set me down a correct path, I would appreciate it. I'd hate to hack this up so much that it impacts transmission functioning, etc. If anyone has an example tune where they did a 25% scaling on an auto, that would help greatly.
Thanks all!
OEM.hpt
TUNE_boost_patch_0004.hpt
