Results 1 to 7 of 7
Thread: 2016 Silverado - Gen V 5.3: Ported Heads/LT4 Pump/LT4 Inj/On3 Turbo Kit (8psi)
    Mar 2013
    43
    Ok Guys,
    I have been tuning since 2011 on HPTuners, but I am new to Gen V tuning. TO add injury to insult, I am trying to correct a tune created by another tuner. The car was on a MAF only tune and refused to go past 4000rpm. I have converted the tune to SD and am attempting to work out the bugs. Although I have modified the virtual torque, I a still having issues. It appears to me that Torque Mgmt is pulling timing in boost. Although I feel like I am moving in the right direction, I want to be sure. Also, I think the trans is slipping under boost as it is making an awful noise at full boost, which is 8psi. Lastly, I read on the forums that I could experience issues tuning in SD only? I have included the tune and a log from the file with several part throttle, WOT, and some idle time. Any inputs would be appreciated.
    Mar 2013
    43
    25 Views and not a single response?
    Apr 2014
    North Dakota
    64
    Both the MAF curve and VVE look very rough. My VVE tops out at 2,400 and yours is up at 3,800 (must be some amazing ported heads you have). Plus your MAF is showing 72 lb/min air at only 4 psi boost, which is craaaazy. I make 50 lb/min air at 10 lbs boost.
    The high airflow is making the computer think it is making way too much torque and you are hitting the peak torque limit, which is probably why the throttle is only opening to 85%.
    My advice:
    Breakout the pressure senor in the MAF to get a better BARO reading. Yours is climbing, which throws off the pressure ratio and makes it impossible to tune VVE.
    Set Virtual torque all back to stock.
    Set driver demand table back to stock.
    For SD, turn on STFT to tune the VVE and use the wideband for PE regions.
    Switch to MAF only and tune with STFT and wideband.
    Adjust the power enrichment enable torque so it turns on when you go into boost. This table references the peak torque table and the calculated torque, so if you change those things it will change how the PE works.
    Idle spark is pretty low, in the scanner, under vehicle controls click the "throttle cleaned" which resets the throttle control and helps fix some idle spark issues.
    2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
    Mar 2013
    43
    Quote Originally Posted by MORLOK View Post
    My advice:
    Thank you!
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    it will not rev past 4000 in sd mode. This has been an issue. I havent been on in a while, so maybe there is a walk around, but the only way I know to dial both models, is to dial in maf first, then use maf data to build a ve table
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Mar 2013
    43
    Quote Originally Posted by mbray01 View Post
    Thanks for your input.
    Nov 2009
    All Around
    3,149
    alot of wrong in that file
