Originally Posted by
blindsquirrel
Do you need a 3bar OS, or just how to change the tune to work with a 3bar MAP? If it's the latter, you just enter the linear & offset in teh littel boxes that match the new sensor.
Writing someone else's repository file is going to cost you credits twice - once before you can write the file and then again after you've created the new PCM serial+VIN combo. Get the PCM flashed with a stock GM calibration using the same VIN and *I think* it won't require relicensing at all. At least it shouldn't as the serial+VIN combo will stay the same.
