Results 1 to 7 of 7
Thread: Speed Density on E38 - 07 C6 Z06
    Mar 2021
    12
    Hey Guys,
    i am beginning my tuning experience with my c6 z06.
    Just put the following together:
    Frankenstein Ls7 Ported Heads
    Greg Good HPC Hulk LS7 cam
    Mamo Ported MSD
    Katech 103mm TB
    Vararam SC1R
    ATI Damper
    C5R Timing chain
    johnson 2110R lifters
    CHE Trunnion Upgrade
    ARH 1 7/8 headers
    3 inch exhaust to stock mufflers
    With built top ends and aggressive cams, do you guys just strictly run Speed density? I see on HP tuners an OS patch that converts the E38 to Speed density, but once you do that, you cannot go back to MAF tuning. Are you just disabling the MAF by adjusting the Dynamic airflow to disable the MAF and force it to run on Speed density?
    I see people claiming better throttle response and easier to tune once its somewhat dialed in. As far as MAF tuning, i know it will help better with transients and drivability, but with such a large and aggressive cam, is that really going to be worth keeping MAF? the MAF is also located right at the throttle body, so the reversion in the intake can definitely impact the signal quality of the cam at lower RPM's.
    Nov 2009
    All Around
    3,149
    running that combo in SD will be much more smoother for sure.
    7,627
    MAF will still work with the speed density OS. I don't know why they put that text in the description, it's not true.
    That's unrelated to whether you should keep the MAF though - in my experience they work best when stored in the junk drawer of your toolbox.
    Mar 2021
    12
    thank you guys for the feedback!
    I think i am going to pull the trigger and not look back and do the 2 bar map OS patch.
    Jan 2014
    Waldorf MD
    774
    If it was me, I'd run both. Tune the SD up to 3-4K RPM and let the MAF do the rest.
    Daily Driver= 2003 BMW 330xi
    Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat)
    Project Car= 1991 Chevrolet Camaro RS (LQ4 w/ Gen 4 Rods, LS3 heads, turbo...)
    Truck= 2007 Chevy Silverado 1500 LT LY5 4x4
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by jaydubb71 View Post
    So how do you do that?
    I can understand it other way around, though.
    Nov 2009
    All Around
    3,149
    dynamic airflow anything below enable will be blend and above will be pure maf
