Results 1 to 14 of 14
Thread: Can't read aircharge parameter
    Jun 2018
    Dubai
    62
    After the latest update of the vcm reader
    I can't read the aircharge in jeep dodge cars
    The software can't find the aircharge parameter when I connect it to the cars
    I used to read it before and has no issue
    Using beta version
    Jeep wrangler 2012 automatic, sprintex supercharger, 9lbs of boost, 4.5" lift, fox 2.5 internal bypass shocks, 4.88 gears, 37" tires,
    Ford Mustang Shelby gt350 2017, airraid air filter, jlt catch-can,
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Quote Originally Posted by Alshuwaihi View Post
    Using beta version
    use the previous version if its working
    Jun 2018
    Dubai
    62
    Quote Originally Posted by outlaw_50 View Post
    Tried not working also
    Nov 2019
    227
    Beta 4.9.1012.0 ?
    I also found this issue too. Accelerator pedal voltage parameter didn't work either. It seems like they may have renamed/restructured the PIDs which is an absolute pain when you have spent quite a while setting up your logging layout.
    Oct 2005
    baton rouge la
    411
    Quote Originally Posted by HaasExp View Post
    Beta 4.9.1012.0 ?
    Agreed. Seems every time Im forced to update it uncovers an issue I never experienced before
    Jun 2018
    Dubai
    62
    Beta 4.9.1012.0 ?
    yes Beta 4.9.1012.0
    i will try now the 23 version
    Nov 2019
    227
    Any luck?
    The ability to disable o2 sensors is also missing from the Beta Editor. I have a feeling this is related to the current emissions uproar.
    I can also confirm that Aircharge is missing from the Beta Scanner. I have to use the current stable version.
    Jun 2018
    Dubai
    62
    Any luck?
    still not fixed - use the stable version for now
    Jun 2018
    Dubai
    62
    Quote Originally Posted by kenandjenn4551 View Post
    also i would love to be able to change the vin number on the pcm
    Nov 2020
    204
    use cylinder airmass instead of aircharge
    Nov 2019
    227
    Found and tried that parameter. It reads very different to "Aircharge" and also drops to 0 when you are off the accelerator and the engine is still running/idling. Very odd parameter.
    Feb 2020
    22
    we need a fix!
    Mar 2018
    28
    Try downloading latest Beta. I opened a ticket as I had a 2021 Redeye and going to older version would not work.
    Latest beta has fix for aircharge.
