Just built this combo and tested on track, overall happy with the results however I know there is much more power to be had from this engine. I have converted from an auto (4l60E) to a six speed manual (T56), I am having an issue when the ABS is plugged in then it constantly flashes with low traction when ever you use the accelerator. Went on the dyno and produced 350 RWHP, I have done some looking into what I should get with this combo and was expecting another 100 or so hp from it. Any help would be appreciated details I have are as follows
Engine
LS1 ARP Rod bolts, otherwise bottom end stock
Double row rollmaster chain with timing set to 0 deg, CamTech cam(was in rotating short engine purchased only info I have been able to get is)
-Advertised inlet: 289
-Advertised Ex: 292
[email protected]" Inlet: 238
[email protected]" Ex: 242
Valve lift with 1.7 Rocker
-Inlet: 0.603"
- Ex: 0.605"
LSA : 110
241 Heads, mild port reconditioned and fitted with Lunati double row springs, trunnion upgrade done
Holey sniper inlet manifold with 102mm throttle body, 440cc injectors fitted
4-2-1 tuned length header's with twin 3" exhaust straight through to lukey muffler dumped at the diff
3.77 diff ratio with full spool
have attached current tune will get logs
VY Berlina Wagon burnout tune.hpt
