First let me say I'm very new to this tuning thing. I have done a bunch of searching but have not found any post that talk about the problem I am having. I had a 5.3 twin turbo in a 53 GMC that bent a couple of rods on the dyno so after converting it to a 6.0L same cam, bigger injectors and the same turbos I'm trying to just tune it for drivability right now and the problem I'm having is as soon as the truck starts to roll in gear the idle jumps up to about 1200 to 1400 rpm and stays there as long as the truck is rolling as soon as you stop the idle drops right down to 650. I tried to set the throttle crack to enable at 100 and disable at 98 but when I do that as soon as the truck starts moving in gear the idle starts to serge from about 500 to 900 rpm any advise would be very much appreciated.
