Hey everyone, I've got a 2016 GMC Sierra with the L86 E92/8l90 T87 combo. The truck was previously tuned by Blackbear as I'd used an Autocal (EFI Live) on my previous trucks and been happy with it. I bought the truck in December of 2018 with 43k miles, and I had it tuned by the end of January 2019. I added E85 in November 2019 which they were able to correct for. Last July, I added a Circle D triple disc converter and have had nothing but problems since. That's also when their customer service took a massive dump and it would take nearly 2 months between communications. After I finally replaced the transmission this past January and BBP saying they could not make the proper changes in the tune (after saying they could absolutely tune for the converter), I decided to make the switch to HP Tuners. So far, I've only made adjustments to the transmission.
I was able to read the BBP tune into HP format, and in so doing I've been comparing it to a few other Gen 5 files I've found on here and a few other places. From the bit of differences I've seen, it looks like this tune may be way off. I'll attach the file for you to peruse. Based on the wild values on some tables (Engine>Spark>Advance>Base>High Octane for example), would I be better off starting with the factory tune as my basis? Obviously, I'll turn off DOD and turn on E85 as the "factory" tune to start from. I've got a Volant CAI, the Circle D 2500-2700 converter, and will be installing a set of Kooks headers/catted y-pipe and AEM wideband as soon as UPS finds the lost box from two weeks ago. Attached is my factory tune and the BBP adjusted tune.
