Results 1 to 15 of 15
Thread: Unknown T43 TCM
    Unknown T43 TCM
    Hoping someone here can enlighten me on this TCM. Part number on the T43 is 24294925 and the OS is 24294926. Any clue on what year vehicle this is from?
    Tuning Addict
    10,766
    Part number or service number? 'Cause the part number will be a made-up thing based on a specific service number with a specific calibration in it (hardware + software = part number; hardware + nothing = service number). Most times the part number isn't available as a reference anywhere, only the service number.
    Its the number thats etched on the TCM. I attached a photo of it. Never seen this number before and nothing is coming up on ACDelco or any GM parts sites i usually use to double check before I try to program them.
    Tuning Addict
    10,766
    Neither number exists anywhere on the intarwebs except for SEO keyword spam sites (a very special thank you to whoever thought up that brilliant idea, BTW).
    I've come up with the same results. I'll see if I can reprogram it with SPS. The guy that brought this to me broke his original TCM removing the connector and breaking several pins in the TCM. He then bought this one off of ebay that said it was compatible with the trans he pulled from a '13 silverado but I have never seen this number.
    That techm can be found in 6L90 from at least 2020 Express van with Gen 4 L96. I have that exact same techm in my swap. Donor VIN#1GCWGBFG1L1121088. I had it flashed with the OS to match my 2014 E38 ECU vin. E38, ECM, GM Gen4 V8 VIN 1GCZGTCG5E1103073 (2014 Express van with L96/6L90) OS 12656198 T43 OS 242652602020-Techm.jpg
    Awesome! Thanks for the info. I was just coming on here to post that I was able to reprogram the TCM with SPS to the 2013 silverado with that same OS successfully. Engine and trans ran good on my run-on stand with no communication issues after the reprogramming.
    And just an added note for future searches. The current GM part number for the Tchem is 24275873.
    -Greg
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Tuning Addict
    10,766
    So is it already superseded or just not in the system yet? 2429xxxx is a very high number, that usually gives a clue as to when a part was released.
    Sep 2021
    2
    I am hoping someone can help me with a similar problem. We just finished building a 57 Belair with a supercharged 6.2 managed by a Holley HP. We also added a 6l80 Mad Dog transmission with a PCS TCM 2650 as the controller. That said the transmission came with a new T43 TCM (24275873) and the OS is 24252573 so the transmission is missing a base profile. Does anyone know the year and model of a car using the same OS. Any help would be greatly appreciated.
    Aug 2016
    384
    Quote Originally Posted by Ejoker View Post
    Searched my files. I got a match (for the OS 24252573) on a 2010 Buick LaCrosse 3.0L w/ the 6T70E
    405
    3,078
    T43 TCM (24275873) is the part # for 2012 and newer vehicles. OS 2425xxxx seem to be used in 2010 vehicles. My experience with "new"out of the box AC Delco TCMs is they are all remanufactured and are expected to be programmed for the vehicle they are going in and can have just about any OS in them out of the box.
    Sep 2021
    2
    tunerpro & 2xLS1..thank you, thank you, thank you.
    As I previously mentioned our customer bought a Mad dog stage 2 6l80e w/3000 stall converter. That said, we began by getting the PCS 2650 TCM to communicate with the trans. We then connected with HP in order to verify and tune the trans but unfortunately we encountered the dreaded P0602 DTC. So we did a deeper dive with acdelcotds and got a bit more information. We even pulled the pan to get the GM part number off the TCM. So here we are gathering bits of information so we can get this thing going. I really appreciate your help. I hope to pay it forward in this forum.
    Yes, I can confirm this is correct
    Yes, I can confirm this is correct. Im presently replacing one one in a 2020 Silverado with 6L80e.
    Was a bitch to find it, but it's correct.
    Chuck CoW
    Chuck Mosello - CORVETTE DOCTOR
    Corvettes of Westchester
    www.CORVETTES-OF-WESTCHESTER.com
    Dec 2024
    1
    Adding in my experience, I purchased a 6l90 with out history for my swap. The T43 TCM also has the part number 24294925. Trans OS is 24294926. Nothing on it on the interwebs.
    Currently running Holley terminator max with the 6l80/90 control. Decided on the Holley set up after speaking to the reps bc they said it didn't matter what the TCM was from since their ecm isn't vin attached. Currently the controller won't connect bc Holley says it is van software and they don't support it from newer vehicles yet.
    Looks like I may need to reprogram the TCM to something older around the 2014 era.
