Why we can't log Mass airflow Voltage ? how cold any body scale MAF without it ?
Thanks in advance
Thanks in advance
I don’t know what type of vehicle you are trying to tune but I have been able to tune my truck’s MAF using a wideband and logging the frequency of the MAF in hertz, not volts.
2017 Silverado 3500HD WT 6.0 flex fuel 6L90 6800lbs E78 T43
--- What am I doing??? Why did I do that??? ---
is it configured to voltage on the channel itself? i can do it on my Tacoma. I found it to be easier to use LTFT+STFT to be easier with the fuel cutoff messing with my data but you can filter that out. can you send a screen shot of your channel config. also are you graphing or using histo?
use Mass airflow (SAE)
see the pic
