Results 1 to 4 of 4
Thread: 5.3 help
    May 2020
    18
    5.3 help
    I have a 5.3 with a btr stage 3 cam, with FF injector, long tube headers, 4.10 gear, and the trunnion kit installed. It ran good before I put the FF injectors in and now I have to hold my foot on the gas to get it to idle and it also does rev up fast at all. also when I give to gas and let off of it to go back to idle to just idles down and dies. can anyone help me out? Thanks in advance.
    devs truck.hpl
    Devins truck 2003.hpt
    13,571
    You should probably change the injector data because that tune file shows that you didn't.
    May 2020
    18
    Devins truck 2003 with FF injertors.hpt
    I just tried this one after changing the injector stuff and it does the same thing
    Mar 2011
    Ripley, MS
    1,865
    It's in MAF only mode. Make sure your MAF is properly installed with no leaks. Or, you can do an SD tune and disable the MAF.
