Results 1 to 6 of 6
Thread: Remove 4Lo throttle limiting in 2016 Tundra
    Apr 2021
    10
    I'm attempting to follow the video description here to eliminate artificial throttle limiting in 4-Lo since I'm out quite a bit in the CO mountains in 4 Lo.
    https://www.youtube.com/watch?v=7kI4K5Wh5Jg
    However, when I go to Engine-> Airflow, I don't have the Electronic Throttle tab you show in the video. I'm working on a 2016 SR5 Flex Fuel. I have the latest HPTune software, and the default tune downloaded by HP tune. Any ideas where I can find that throttle angle? See the attached screenshot.
    Thanks in advance!
    Todd
    Quote Originally Posted by tnine View Post
    Thanks in advance!
    Todd
    The tables you're looking for are under Airflow -> Electronic Throttle -> Limits -> 1st Gear 4WD Low and Rev Gear 4WD Low
    You can reference slide 44 in my tuning reference guide, linked in this post: https://forum.hptuners.com/showthrea...ning-Reference
    EDIT: disregard above, just re-read and looked at your picture - please attach a copy of your .hpt file, I would like to take a look
    Apr 2021
    10
    Here's my HPT file. Thanks for helping out! 2016-Tundra-SR5-5.7-Flex-Fuel-295-70-R18.hpt
    Took a look, was able to access the tables without issue, here's the edited file: 2016-Tundra-SR5-5.7-Flex-Fuel-295-70-R18 4LO Edit.hpt
    You need to switch to the Advanced view in VCM editor (Edit -> View -> Advanced), then you will be able to see the tables.
    Apr 2021
    10
    I missed that detail when I was setting up the initial tune. That solved my issue, thank you!
    Jun 2022
    Quote Originally Posted by SlowNStock View Post
    I have found that this 4Lo delete does not work (1st gear 4WD Low = all set to 86 degrees). I have 40s, which exacerbates the issue and makes it easier to reproduce, on my Tundra with 5.29 gears and I still experience the engine not willing to rev up.
    I've also tried the following:
    Trans > Shift Scheduling > 4WD Low > 1-2 (all maxed out to 6500rpms)
    I'm wondering if modifying this will work: Engine > Electronic Throttle > Limits > Torque Based > High Load
    Because it shows that at low RPMs, for a stock mapping, the throttle is only at 6.2 degrees @ 400 RPMs for 111 lb-ft of torque. I'm thinking that even if the 4Lo delete is set to the max of 86 degrees, it actually never gets there because of this mapping. Your thoughts?
