Long story short, 2014 Silverado with a single turbo, 6psi runs and drives great .Just one problem, If I accelerate at a medium speed the truck will start to build boost and once it does the throttle position will start moving towards a 100% even with the accelerator position never moving. Below 30% throttle the truck will accelerate and shift from 1-2-3-4 without issues and the map never goes over 100kpa. At WOT the truck hauls and has no issues. If I accelerate moderately enough say 40% the truck will start making boost around 2500rpms. At this time the throttle will start opening and then go wide open even though my foot never changes position on the gas pedal. I see desired throttle air flow and actual airflow are really close when everything is normal. when the truck starts making boost at part throttle I see actual airflow goes up and throttle airflow stays the same and then the ecm starts opening the throttle to get the desired throttle inline with actual. So I know the problem, just looking for a little direction on what to do to keep the throttle from opening as boost comes in.
Thank You
Bad383TA
