Originally Posted by
Stevekreger
from the last log, driver demand limit says "combustion stability" also torque airlimit source says "popcorn". under torque management/general bump your max map up to 80 in/hg this should stop the limiting, it will say "you are exceeding min/max limits hit ok anyway. looks like you need to up the expected tip tables to maybe 40 psi or so. they are set to 31.93 on the high end. also your max vs turbo airflow table is set to 29.47, bump that up to 40 also. this is all under airflow/pressure control/ throttle inlet pressure settings. keep in mind these are absolute pressure settings, thats why they look really high.
