Aircharge multiplier and maximum load tables in SD need to be populated to allow the demanded torque to go up with load. This should help the engine torque limit.
You will also want to populate the MAP delta table, just leave the lower RPMs, 3000 and under, at 0. This allows the TB model to not freak out about the airflow going through it, because it allows it to not be at barometric pressure.
Load goes up .8, and you only see a 100lbft increase in torque, thats a limit. The increase should be three times that.
At 15 PSI of boost, 2 bar, you shouldn't be over 2.0 load. Unless you have something lacking in the fuel system. 1 load is standard atmosphere conditions in the combustion chamber, so 2 is double that. You have to account for volumetric efficiency and the fact that your air charge temperature is a bit higher than STD parameters. so 1.8-1.9 load for 15 psi is great.
You are also reaching 13,000hz MAF frequency. There is no limit to a digital MAF in theory, and you could just keep going up, but you are asking a lot of the controller and sensor at this high frequency. Most OEMs shoot for 10k, and don't even populate above 12.5K. This can be fixed with the size of the pipe it lives in.
