I have an 01 silverado with a 12208322 os that I want to upgrade my 05 electric fans to have full pcm control.
I purchased a fan harness from BP Automotive along with their A/C update kit.
Everything is installed and I can control fans with bidirectional, however the fans come on right at start up and don't turn off.
I have done some searching and this seems to be a common problem with the 01 trucks and the fix seems to be to change to the 12212156 os from a 02.
So all I need to do is open the comparison log differences. and copy over all differences, license the file and write entire to the truck.
And this should work just the vin will not match.
If I need the vin to match I will need to use the change vin wizard and license the file again, correct?
