Results 1 to 6 of 6
Thread: Active Exhaust - Loud Startup in Quiet mode
    Feb 2021
    UK
    12
    Recently had my headers replaced with LTH's and it made things a little louder.
    Quiet mode on the active exhaust is fine though.
    However when starting up, there is an initial load bark from the exhaust and its runs loud for several seconds, before settling back down into the Quiet mode.
    So is there a way of keeping quiet mode quiet?
    Nov 2009
    All Around
    3,149
    with your car its not much a quiet mode as a stock tune needs to be adjusted for cold starts to help eliminate that very loud cold start
    Feb 2021
    UK
    12
    Quote Originally Posted by SultanHassanMasTuning View Post
    Thank you for the response, is this something I can be talked through, or its it an involved process that needs to be done by a tuner?
    Asking, as I'm a newbie to tuning in general (own my own MPVI2), but have only tweaked a few small bits under guidance.
    May 2021
    13
    Check out my thread called "Cold start Cat warm up timing table". On my 2014 I was able to adjust this and make the car start normally. Although some in the thread said it did not work for their 18. Try it out and let us know.
    Feb 2021
    UK
    12
    Quote Originally Posted by Admir101 View Post
    Had a look, thanks, ut slightly different for me on a Gen3 S550.
    I have cats, so removed the retarding below -2.0 from the in neutral idle table, so if below -2.0 its now -2.0.
    This gives me a 1-2 second initial bark only.
    Now the car is complaining the cats are not hot enough, so need to block the warning, to remove engine management indicator.
    Feb 2017
    TX
    761
    In Spark > Advance. YOu have your Base Emission Reductions spark tables.
    Base Drive and Base Neutral, set the whole table to 55*.
    11535 and 11539
