Results 1 to 6 of 6
Thread: 2007 Escalade 6.2 (408) engine and ECU
    Jun 2021
    Louisana
    4
    Working on a project that has a 07 6.2 (408) 11.5-1 cammed and ECU out of a Escalade using a truck harness. It will start and run for a few Seconds and stall. Made changes in ECU DOD off, VVT zeroed out, idle raised air flow adjusted up to 50% over stock and still no change. It is still running rich when it does fire AFR around 10.6. Anyone ever run in to this issue?
    13,559
    Post the tune.
    Jun 2021
    Louisana
    4
    13,559
    Was a write entire done when the VATS was turned off?
    Don't forget to set the camshaft under the variable camshaft tab from one to none if you removed the VVT cam and installed a non VVT front cover.
    Jun 2021
    Louisana
    4
    I will check out vats is was eliminated so I was told and on the VVT all I did was change all my numbers to 0 on the charts.
    Jun 2021
    Louisana
    4
    Found the issue I believe in the Mass air sensor
