dash reads no oil pressure after writing a tune
vcm reads it good
vcm reads it good
No clue why or a fix, but I’d try disconnecting the battery for a few minutes. Maybe some form of communication error between modules after the write. A scanner capable of reading all modules might be beneficial as well. See if any codes are stored.
thanks for the reply and ill try it
Check the connection at oil pressure sending unit on the valley cover and if you run any power inverters or plug anything else in to your pc make sure to disconnect all of that when uploading/logging. All else fails make sure you have the lastest vcm suite version downloaded.
