Before I address my concern, no major upgrades to my truck. A 1999 5.3 with .212/.218 Texas Speed Cam with cold air intake. I also am running in SD open loop with a MAF delete. I have relocated my IAT towards the front around the grille. So my primary concern is how my 1 bar stock MAP is maxing normally shortly after I go into overdrive. If I am fixing to go up a hill shortly after it shifts into OD that is where the MAP readings hit the max and it's typically accompanied by a very noticeable stumble a time or two. My AEM wideband kit comes in tomorrow so I can start tuning to perfection. I have been trying to get it in the right direction since now. IDK what these high readings and stumbling are caused by but I would assume something with AFR I haven't noticed due to narrow bands but tomorrow that will be corrected. Any advice to my tune? anything odd in my latest log? PLEASE GIVE ME POINTERS! I am much newer to this but learning fast.
